How do I turn off the module beep?【 DFR0768 】 FAQDFR0768
"Cannot read or The analog reading is always 0" 【SEN0203/SEN0344】 FAQGravitySEN0203SEN0344
Why is the display normal but not sensitive to touch?【DFR0550】 FAQDFR0550
Makecode programming cannot connect to EasyIot/ThingSpeak.【MBT0034】 FAQMBT0034
The sensor reading is abnormally large or unchanged.【SEN0240】 FAQArduinoSEN0240
The UUID keeps changing or doesn't show up.【TEL0095】 FAQTEL0095
ME007YS waterproof ultrasonic sensor does not work. 【SEN0312】 FAQSEN0312
Why does my screen not light up or display very dimly after uploading the program? 【DFR0063】 FAQDFR0063
The sensor data is turbulent and fluctuates greatly.【SEN0322】 FAQSEN0322
What is the size of the white detection area of this sensor?【SEN0376】 FAQSEN0376
How to quickly start using UNIHIKER K10? FAQDFR0992-EN
What expansion boards does UNIHIKER K10 support? FAQDFR0992-EN
What sensors does UNIHIKER K10 support? FAQDFR0992-EN
What are the differences between UNIHIKER K10 and UNIHIKER M10, and how should I choose? FAQDFR0992-ENDFR0992-EN-1DFR0706-EN
What are the differences between UNIHIKER K10 and Huskylens? FAQDFR0992-EN
Is the SEN0440 MiCS-5524 pre-calibrated for these gases? Also, NO2 is mentioned in the Wiki etc, does this model measure (again, pre-calibrated) NO2? FAQSEN0440
How do I turn off the module beep? 【 DFR0768 】 FAQDFR0768
What is the specification of the speaker interface? What parameters of speaker are supported? FAQDFR1154
- 5 FireBeetle ESP32-E Boot Mode
- 6 Comprehensive FAQ Guide for LiDAR [DFR0628/DFR0445/DFR0315]
- 7 Problem with Calibration of pH Sensor / Meter Pro Kit V2
- 9 ESP32 FireBeetle development board current consumption too high
- 10 Offline Voice recognition SEN0539
