sen0562 (waterproof light sensor) minimum high voltage level General GravitySEN0562
Gravity I2C Waterproof Ambient Light Sensor; Datasheet Required GravityGeneral SEN0562
Set i2c address of the sen0562 ? ArduinoSEN0562GravityHow to select
Range of Wavelengths SEN0562GravityTroubleshooting
Gravity I2C Waterproof Ambient Light Sensor Temperature Compensation General GravityArduinoSEN0562
