I'm having trouble getting the encoder outputs to work with FIT0487 General FIT0487
Can't get encoder outputs working with FIT0487 - they're open drain, right? TroubleshootingFIT0487
For DC motor FIT0487, exactly which JST connectors? How to selectFIT0487
