problem calibrating SEN0161 (adjusting gain potential device) General SEN0161-V2SEN0161
PH Sensor code doesn’t use temperature General SEN0161GravitySEN0161-V2
Question General Raspberry PiSEN0161DFR0300-HGravity
amps used needed for Gravity sensors General ArduinoGravityDFR0300SEN0161SEN0137DFR0026SEN0043
EC and PH meters with raspberry pi pico and zero Raspberry PiGeneral SEN0161DFR0300-HGravity
pH Meter V1 & V2: License and schematic General GravitySEN0161
