Hello,it's possible to reduce the fov at 8°?With 15° the measure is good untill 1.50m, after, for 2.00 the measure are 1.70 to 2.20m.Thank You very much. https://uploads.disquscdn.... FAQSEN0337
What kind of shaft does this encoder have? Is this a D shaft knob? That needs to be in the spec. FAQSEN0235
I interest the M.2 ethernet card,it's a new product of dfrobot? Can you provide me 3D file ?Thank's in advance FAQFIT0798
whether the base robot also compatible with the servo DSS-M15 DF Metal Gear Standard Servo 15Kg 180°? FAQROB0114
http://download.dfrobot.top... is still 404 FAQDFR0652
Does it comes with a pin and if so whether it is soldered to the company? FAQSEN0435
I am using a moduel CM4 with wifi, but the OpenWrt that I found in the DFRobot work well with the 2 ethernetports RJ-45, but I can not see the Wireless module or any Wifi configura... FAQDFR0767-2
Are we to remove the aluminum heat shield prior to fitting the main sink? (cpu- thermal pad - heatsink)Or does this just go on the outside of the shield? (cpu- thermal pad - alumin... FAQFIT0677
Hi, It is capable to get only Capacity and Voltage?... Could you use I2C bus to get other kind of data like charging current or output current? FAQDFR0865
Hey, anyone know who manufactures the actual screens? I'd like to know which chemicals are used for the liquid crystals for OH&S. FAQDFR0664
Can i connect this LCD to the Arduino Expansion Shield V7.1? I cant find the RESET pin in this expansion shield, and this lcd need to connect to the RESET pin FAQFIT0328
Hi!If I understand correctly, this module with antenna is the transmitter. Can the same module be used as receiver? So this would mean that I need to buy 2x this module to be able ... FAQTEL0125
Does the devastator come with plastic or metal gears? FAQSEN0305-2
Does this shield work with DFRduino UNO R3 - https://www.dfrobot.com/pro... FAQDFR0210
