How to get the default firmware back on the I2C Adapter Telematics General
OBD-2 I2C adapter not working on Pontiac Telematics General
help getting Arduino OBD-II Logger Kit #2 to run Telematics General
OBD 2 Modes in OBD 2 I2C adapter with gyro and accelerometer Telematics General
OBD-II I2C adapter and 3.2" TFT LCD Telematics General
About Freematics OBD-II Adapter and Freematics OBD iOS app Telematics General
Re: Announcing the online OBD-II/GPS data charting service Telematics General
How to make the SD card socket on the TFT LCD shield work with Arduino MEGA 256 Telematics General
TFT Shield screen has 1/4 inch black down leftside Telematics General
The obd won't start if the arduino monitor serial is not open Telematics General
How to use softwareSerial with OBD-II Adapter? Telematics General
OBD2 UART with Arduino UNO is not working Telematics General
Arduino OBD-II data logger kit Telematics General
I can't make the pid_speed work.. Telematics General
Vehicle won't start with ODB2 connected Telematics General
Which Pin is the SD card on the back of the LCD? Telematics General
Re: Re: Freemantics OBD II Adaptor - Startup Telematics General
