Counting objects with Huskeylens and pulsing I/O General HUSKYLENSSEN0305
What is the range of HuskyLens? General HUSKYLENSSEN0305
Is there a way to make the HUSKYLENS recognize an object that isn't one of the 20 built in objects? General HUSKYLENSArduinoSEN0305
HuskyLens multiple training with MicroSD and Documentation link nedded HUSKYLENSGeneral SEN0305
I want to use object recognition but the builtin Led on the huskylens does not turn blue General SEN0305HUSKYLENS
How many objects can HuskyLens recognize? General ArduinoRoboticsHUSKYLENSSEN0305
Can i detect a smile or other facial expression with Huskylens? General HUSKYLENSSEN0305
HUSKYLENS 2 MP TO 5 MP General HUSKYLENSSEN0305
HuskyLens does not communication through UART with Arduino Mega 2540 General HUSKYLENSArduinoSEN0305
Processing time of huskylens General HUSKYLENSSEN0305
Mounting the Huskylens on FVP nylon Pan tilt General HUSKYLENSSEN0305-S
Are there compatible OV2640 cameras with longer leads or different lens for the HUSKYLENS? General HUSKYLENSSEN0305-S
Questions on Object TRACKING on Husky Lens General HUSKYLENS
Connecting Servos to IO Extender for Microbit (the one used for Husky Lens) General MBT0005SEN0305HUSKYLENS
Huskylens x Lego Spike General HUSKYLENSSEN0305
object recognition issue HUSKYLENSSEN0305General
