Comprehensive FAQ Guide for Gravity: Capacitive Fingerprint Sensor [SEN0359] FAQ
Can this display be used on raspberry pi 4 model B FAQFIT0955
Very Interesting Design! Do you happen to have schematics for this? Would love to use with the TCS3200 Sensor you offer. FAQTEL0153
Here is my library for this sensor as well as the wind vane using RS485.https://github.com/wilson-m... FAQSEN0483
Hello, I would like to know if the accuracy of the NO2 value at the output of the DFRduino UNO R3 (assembled with MICS-2714/SKU:SEN0441) is also 0.05ppm (like that of MICS-2714), o... FAQSEN0441
Hello, I’ve been tasked with purchasing an Odor Detector, specifically the ‘Fermion: MEMS Odor Smell Gas Detection Sensor (Breakout, 0.5-50ppm)’. However, I’m unable to determi... FAQSEN0571
Dzień dobry,Czy silnik będzie działał na napięcie 3,3V? FAQFIT0578
for a 12v power supply, what is the smallest number of watts i need to run the full lite board? FAQDFR1142
Can we use this item as is. Connect 5v, ground andWhen there motion detect the 'out' go hight 5vIf so I need this asap FAQSEN0609
Can i confirm that the M.2 E Key slot is only 2230 and will not be able to fit 2280 SSDs like the Samsung 990 Pro? The pictures like like it may fit, so i am crossing my fingers he... FAQDFR1141
When is it possible to get the NAS carrier borad for it? i can't seem to find it here yet. FAQDFR1146
Hellowith reference to the:MODBUS-RTU RS485 Soil Temperature, Humidity and pH Monitoring Sensor (IP68, 5-30V).. limitations? could i use arduino with short burst pH measurements to... FAQSEN0602
I feel that every time I purchase a product from DF Robot I'm left with no support and sub-par implementations. Don't get me wrong, the hardware is great, but the firmware / librar... FAQTEL0157
Is there a 3D model of this case which you could share? FAQFIT0949
Where can I find information on the exact model of the LEDs? It's not in the product wiki. Thanks! FAQSEN0364
Comprehensive FAQ Guide for Gravity: Analog Electrochemical Carbon Dioxide Sensor [SEN0159] FAQ
Comprehensive FAQ Guide for Fermion: BLE Sensor Beacon [TEL0168] FAQ
Can Lipo Charger-type C ( SKU: DFR0668 ) connected with Gravity: I2C 3.7V Li Battery Fuel Gauge ( SKU: DFR0563 ) ?Since i want to know the battery (lipo) remaining fuel (shown in t... FAQDFR0668
what should I do to make this amplifier withstand 200W, can I put a 2ohm speaker in it? FAQDFR0675-EN
